Telstar 12!! Please help!!!
  • Thread starter Thread starter 15satman
  • Start date Start date
15satman
Hi
I am trying to recieve Iranian-American channel NITV which has relocatd to Telstar 12 at 15deg. west to avoid being jammed by the Iranian government.
I am in south Wales, and i bought a 1m dish which as i understand is more than the 80-90cm required for the 49-50db signal. However, I cannot seem to recieve anything, I dont have a meter, but in the past have never needed one as I find analogue channels on the closest satellite to the one i want, then switch to digital and move very slowly and wait for a signal.
My elevation as far as i know should be about 30 degrees. On my dish there are one set of numbers on one side and one on the other each in different increments I dont know which one to use!!!! One goes up in 5s but im not exactly sure.
Are there any reasons why i cant recieve from this satellite? I have tried calling out specialists, but none of them will do it either because theyve never heard of the satellite or they dont have a "spectrum analyser" or they just think its pointless...
Any tips are greatly appreciated...
Harmick
First, check your settigs for NITV. They should be:
freq=12612
pol= H
sr=4123
fec=1/2
(data from http://www.lyngsat.com/t12.shtml correct at 31/jan)
Second, you see from above that the same beam is used by other transponders, so check you can receive them.
Your dish is easily big enough.
Check elevation/etc using the excellent free program SMWlink"
Download here: http://www.smw.se/smwlink/smwlink.htm
2old
