- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
Perhaps there is solution how to use original LNB holder on CM120. All is needed is to lift LNB in the holder (longer INOX screws are to be inserted) , and some kind of spacer under LNB (I put a pencil, but it is just to demonstrate). If LNB axis is leaning downwards 8,1* and it is lifted about 10mm, than it is possible to improve performance of the system.
