Archived-1
Persona non grata
- uk
offset angle of CM120 is 22,6
Something ive never thought about, is the offset angle the same on the 1.8 please ?.
Do not believe that! It can not be 1400mm1950mm x 1400 x 173,
Do not believe that! It can not be 1400mm![]()
,Splitting hairs springs to mind
, I have lots of tools, but nothing to measure the size of a nats coc*so we are speaking about 4mm only. But, if you wish to calculate precise focal point antenna has, you should measure everything with maximum precision possible. For example, for your CM1.8m if you use depth measurement 173mm, than calculated focal point will be about 5mm away from real one. If we have technical possibilities to do precise measurements than we should not use this possibility.the best place for the lnb is slightly lower than were the manufacturer puts it 4mm to be precise
Martin! You mentioned before
so we are speaking about 4mm only. But, if you wish to calculate precise focal point antenna has, you should measure everything with maximum precision possible. For example, for your CM1.8m if you use depth measurement 173mm, than calculated focal point will be about 5mm away from real one. If we have technical possibilities to do precise measurements than we should use this possibility.
