TF 7700 + Trex 4.6 problem
tomiku
TF7700, mot. dish
PL
Any suggestions to such a problem:
Tuner can see the module, everything works, menu of module, properly decoding, etc.
When loader card is in - constant message: initializing.......
When module with loader card inserted into humax, ferguson, etc,( I went to the store) it works - is seen as update - after updating and removing the card, module can be used back in TF. tried in different TF in the store - the same, so it is not my unit is faulty.
My asumption is: module, soft, loader are ok, TF or TF soft is not.
I have seen the same problem mentioned on German board, but can not find the answer.
Any suggestions, please.
Rgds.
The best solution is to buy a CAS 3 +, programmer, this will allow you to update your Cam, using the Cas 3 and dummy card, without using your receiver.
Also the Cas 3 + can programme Diablo Cams, which might be your next purchase, as it is better supported and opens a lot more channels.
Thanks Mickha,
It has crossed my mind before, I have bought a usb unlimited prog., because looks like a simple solution.
Buying cas3+ now is a half price of a tuner.
As of more channels open, I have not noticed, for sure the files for diablo come out quicker.
My last hope is a soft in a tuner, which I have not tried yet.
As for loader card in a module I was hoping for your help in maybe re-naming some files, or something. It is strange, that without a card everything is ok, with the card is not recognized.
Rgds
As well as the channels the T-Rex is getting the Diablo is also opening TPS and Showtime. Also it has AU on D+ and Cabo.
Thanks Mickha,
Opens french, but you have to load it everyday?, anyway most of it is dubbed, sorry for asking, but due to the name, it is difficult to search - which showtime, where is it?
Rgds
TPS is AU, you just leave your receiver on France 4, or other channel on the same frequency, for a minute and the channels will open.
The only problem with showtime is the dish size required, 2.4 M, where I live, to receive the channels that will be showing the English Premiere League.
I have solved the problem.
Bought the CAS3+ for programming the modul.
But solution is different.
In CAS there is an option of repairing the Loader card.
I run an automatic loader card repair that is in cas studio.
Programmed the card with Infinity with new pred as usual.
Inserted it in TF77 - and - now it works!!!! You can see the trexupdate.
Maybe will be useful for somebody. Before you could see trexupdate with any receiver, but not with TF, showed only initializing..... But in TF, modul alone worked OK. Running the repair, changed obviously something, that TF recognizes it and you can update the modul now.
Thanks for help, my cas is useless, but you never know in future....
Rgds.
