ticket??
  • Thread starter Thread starter MUSAFFIR
  • Start date Start date
M
MUSAFFIR
can someone tell me why i only get ticket 6, 7,8 and not the rest of them? because the are some good movies on 1,2,3,4,5,6????:confused:
What cam and receiver are you using.
You can get all tickets with freecam 2-019.
However if you are using the Eurocam with 6 in 1, then it not possible to get the remaining tickets because of the way the cam handle the decoding commands.
Regards
Prince
They seem to have discontinued the 4000 model, So you can either buy a freecam or magic cam or get a viaccess cam for those movies channel.
http://www.technomate.com/home.php
Click on support and software download.
I have a Techomate 5000Dapci for which there is a new software,
as soon as I have chance to upload it , I would let you know if it solve those movies channels problem.
Regards
Prince
i have the same problem with a samsung dsr9500 = irdeto 5-1 patch,
only way i can get round it is by using a viafun card in embedded slot, seems weird but it works O-Ha
aslo have the same trouble with a lot of canal channels too :confused:
Which 6 in 1 is giving you all tickets? is that with the latest software dated 10 December or earlier.
Regards
Prince
