It's been a while since I started this thread but I finally managed to get some spare time to have a play with this 20cm SMW dish in Helsinki. It was a nice calm morning with just some light cloud to the south.
I haven't tried the original circular LNB yet but I found that a narrow Alps LNB fitted the best for linear reception on this unusual setup. Standard LNBs where simply too wide as the feed arm was in the way. You may also notice from the pictures that I used a rather crude way to hold the LNB to the arm using a safely arm band reflector that I had lying around which allowed for easy adjustment of the LNB to find the best signal.
Results were not brilliant, but I wasn't expecting too much on this size dish. I think one of the biggest issues is the beam width of the dish is so great it's too easy to pick up unwanted interference from nearby satellites. I could see as I moved the dish around how signal levels didn't vary much over a large area. It certainly made finding satellites easier...
First I tried 1°W. I could only lock one transponder, 11.421H at 8.3dB on the DrHD F15. Most of the other Nordic beam transponders where showing between 3-6dB but not locking due to the FEC used. The wide beams where under 2dB and Intelsat 10-02 beams were non-existent.
Next I swung the dish over to 5°E. Most Nordic beam transponders where under 4dB but I managed to get a lock on three transponders at this position:
11.727H 7.1dB
11.862V 5.7dB
12.476V 7.0dB
Moving further east, I couldn't find a recognisable signal from the Hotbird cluster at 13°E but I did manage to see the right pattern of transponders from Astra 1 at 19°E so I knew I was on target here. No luck with locking anything as most signals where under 2.5dB but 10.964H (3.9dB ) and 12.574H (4.2dB ) where the strongest two transponders according to the DrHD F15 receiver but sadly not enough to decode a signal.
Then I moved on to Astra 2 at 28°E. Unsurprisingly I could only see a pattern of signals from the Astra 2G Europe beam. 11.225V was coming in at 3.2dB but wasn't quite enough to lock it. Most of the other 2G Europe transponders where just under 2dB. Nothing from 2E/2F.
Finally, I also had a quick look at Astra 5B at 31.5°E. 11.954H was the strongest at 3.2dB but again no lock. I'm also reaching the limits of my view of the Clarke Belt to the east from this location.
So that was just four transponders that I could lock from two orbital locations using this dish in Helsinki and rather annoying nothing that I could watch as the transponders all contained encrypted stuff.
Next I'm going to take it to Maidenhead with me to see how it does in the UK. Hope to get slightly better results there. I'll report back once I've got some information to share.
