tit in force problem
snorre
Force1122
hi guys,
got me a brand new blue tit.
burned it (after extensive research) with tmb2.9, the latest f*les and a mastercard2.
everything went fine until i put it in the c* slot in my force1122.
nohting happend except "checking card"...
is it me or the force or...what?
any help would be much appreciated.
muchas gracias
snorre said:
hi guys,
muchas gracias
I sometimes had the same problem with my 1145S, never cured the problem, in the end I used a Matrix Revolution cam with MRV.bin files, always works OK.
THX satslut
ok guys,
after downgrading the tit to 03 and
burning the latest f*les finally my
force accepts the card, but i only
can watch cd nl (c+ is dark) and
some of the via channels like tps...
shouldn't there be more available
except d+ and the thor channels....?
thx again
snorre
I have the same receiver as you never been able to make the internal cams work, please could you enlighten me about the Matrix cam and how it fits in the Force, been using black ice cam but it does not get much - machno
