Tm 6900 hd super combo Power supply problems?
zudrick
Sky+HD 1TB
Technomate TM-6900D
FTA/Scrambled Satellite from 55E to 45W
Channel Master 1.2m Dish, Jaeger SMR 1224
Diablo 2 cam
North Lincolnshire
My tm 6900 hd super combo powers up ok and after a few mins the screen flickers and the whole set freezes can not do anything with it other than switch it off wait then switch back on but it will do it again in a few mins. I have noticed that if i've got my usb drive pluged in it seems to do it sooner. Any help on this matter would be most helpful.
Hi zudrick,
Try this... switch the TM 6900 'Off' using the power switch on the rear of the receiver... then press and hold down the 'Menu' button on the front of the receiver as you switch the TM 6900 back 'On' using the power switch on the rear of the receiver... you will then see the 'Loader Menu' on screen... try the 'Factory Reset' option on the list and see what happens... also try the 'USB Download' option... I hope this helps...
Best Wishes,
Zorch
Car'nt use the USB Download option cause it locks up before it finishes. Have restored firmware over serial that went ok
