Advice Needed TNT Sat receiver with card
Bamboccio
Hello,
I am thinking of getting a cheap TNT Sat receiver with card for Astra 19.2.
Do you have any recommendations?
thanks!
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
The same tv channels are FTA with a multistream receiver from 5°W.
Edision Primo IP S2 Full HD Linux H.265 HEVC Sat Receiver​
Bamboccio
I only have Astra 19.2. Would this one work with a TNT Sat card?
Thanks!
Go the the TV Corner website shop - they have a range of TNTSat receivers at reasonable prices. Ive used TV Corner in the past for subs cards and never had any problem with them.
Since the channels are FTA on 5W, buy a cheap SKY Zone 2 dish & LNB (or something similar) and set it up on 5W (you will need that to get 5W) - then add a simple DiSEqC LNB switch and set your receiver to switch between the 2 dishes to get both 19E & 5W.
That will be a LOT cheaper than another sat receiver and a TNT subscription.
Edited: even if you have to buy a Multi-stream receiver such as an Eidision or an Octagon SX88+ then the latter will still be true after a few months.
Bamboccio
Thank you to both. I cannot put up another dish so I have to use the existing 19.2 signal.
I may get the Cahors Teox receiver.
I wonder if anyone knows the brand.
Pablopk
TM 2600 motor and dish, single LNB
London
Alternatively the boxes for 19.2 are really not expensive and the card lasts 4 years. I don’t think any of the boxes are brilliant l. The Strong 7402 does the minimum.
If your receiver takes CI+ CAMs, then it might be worth getting of those (with card) instead of a whole new receiver.
dreambox1959
46.3N-4.3E-FRANCE
france
Cahors (like the french town) is the new brand name for visiosat !!
It will be somewhat cheaper - even after shipping - if you order from the other side of the channel.
I don't know. I saw a few on TVCorner but not sure what service they were for.
