TPS help
J
jayko
XXX
DM500+, DM800, CubeRevo HD, Sky UK HD x2, Viasat.
U.K
i have a conax blue titanium smart card and matrix reloaded cam yesterday i was watching all tps (movies etc.) and all multivision channels and today theyre not working, so i went into menu common interface mr.070 then card information and it said insert available card with cam and yesterday it said conax card inserted please help what is the problem???
im using echostar ad-3000ip.
M
Marts
90 cm dish + two LNB 13/19 E
90 cm dish + one LNB 30 W
Humax 5400 .. Oh and cable for Mrs Marts (smilie here)
Gozo - Malta
Three threads, same question jayko
J
jack-le-frost
Echostar 3600
1.2 channel master
loads of cams and cards
and extra bits and bobs
northwest
Hi jayko the card you have got is a blue tit card not conax card.
and the Matrix cam software can you confirm is mr.070.
If it is 0.70 the you need to update to the latest S/W by using 2 fun 6 cards
and use a programmer to put the codes onto the cards, if you need further advice please ask
J
jayko
XXX
U.K
ok, where can i get these codes from? and i have an infinity usb reader so, what do i do? point me in the right direction. Where to get codes etc. how to put them on my card etc.
Much Appreciated.
J
jayko
XXX
U.K
.......................:rolleyes: OK... So What Shall I Do.?
