Hi
I’ve been following the “loss of Ch 4” thread on this forum for a while, and then saw this thread last week. I thought I might have a valuable input to the transponder power debate…
Several contributors seem to have accepted as fact that satellite transponder power output is fixed when the transponder is manufactured, and can not be altered once the satellite is in orbit. This is possibly causing some confusion. It is the GAIN of a transponder which is fixed; notwithstanding that this tends to deteriorate with spacecraft age. Power output can be (and routinely is) varied throughout the life of a spacecraft (and often on a daily basis), by altering the power of the uplink for a specific transponder. The over-riding factor which determines how much power is allocated to each transponder channel is the power available to the overall comm’s payload of the satellite (i.e. from the solar cells, less platform overheads such as inertial stabilization {e.g. three-axis stabilisation as found on Astra 2A and 2B} ), and often more importantly, the amount of power which can be “eclipse protected” (i.e. the battery back-up the spacecraft has to rely on whenever it is in the shadow of the earth and away from the sun).
One of the main functions of a satellite control centre is to “power-balance” the spacecraft. The only power which is available comes from the solar-cells (or batteries during an eclipse). No spare power can be stored; you can’t add an extra battery or two. Conversely, there is no source of extra power available. I believe that SES (Astra) actively monitor the radiated power from every channel on every transponder on their fleet of satellites at several (?? around 6??, need confirmation) sites throughout Europe. The output power of each channel (note, each channel, not each transponder) is constantly modified in attempt to maintain a specific signal-to-noise ratio at each receiving site. For DTH television these “receiving sites” could potentially be every home within the target area, e.g. for most BBC channels this is the whole of the UK, assuming that each home had a correctly installed dish of the appropriate size… but that is a discussion for another thread.
I personally believe that the problems we have seen here “on the fringe” over the last few weeks/months have more to do with the fundamentals of satellite communication. Personally I’ve been keeping an “eye” on the orbital positions of Astra 2A, B and D since I started loosing Ch 4 at the end of last year (wot! no ER !! no Big Brother !!!). The positions of all the Astra satellites (and many, many others) are published daily by NORAD (try a google search for “NORAD two line elements”). To translate these figures into something a bit more useable I use some free software called “Satscape” (again a google search will find this).
The upshot of all this is that Astra 2D seems to have been moving significantly eastwards since the back-end of last year {2006} (see 2 attached jpgs, which are taken from satscape “3D” screen-shots, Dec 06 and Feb 07). My theory (for what it’s worth), is that here in the fringes of the footprints, many of us with large enough dishes to recieve UK terrestrial TV have been “tweaking” alignment to follow 2D (to maintain BBC) for some time, but we may have inadvertently lost some 2A verticals (including Ch 4). Sooner-or-later (I believe…) there will have to be a station-keeping burn on 2D. That is that SES will fire its rocket motors to move 2D significantly westwards (and shoten its in-service life at the same time).
A good test for this theory would be if there were a significant number of Astra 2 “users” in fringe areas who hadn’t enough antenna gain to receive 2D (couldn’t receive BBC/ITV etc.), and so hadn’t gone “2D” chasing , who hadn’t noticed any significant change over the last couple of months. I’m sure there are plenty of suitable contributors on this forum.
I realise that I’m possibly asking to be shot down in flames with this posting )(-red (please be gentle..)
but I at least hope that readers will realise that there is still a bit of “rocket science” involved with satellite communications.
