Tuning problem with monoblock and gemini 2.20 for DM500
ebmaster
Likes
just got a DM500.
Getting alot of grief when choose the simple disequ config to tune dreambox with gemini 2.20.
If i just choose one lnb i get all the channels - not sure why the dual setup doesnt work. Any ideas ???
Likes
1,287
#2
OK, have you had the monobloc working correctly, or is it a new installation? What is the main focus of the dish? Which satellite can you receive?
Likes
1,287
#4
What settings do you have for each satellite in the DB menu?
ebmaster
Likes
hmmmm......
i zapped gemini out... and put on SF team and now the screen is flashing...dark black and lighter black.....
looks like i need to find my null modem cable :-)
any ideas if rudream is worth a try....i got the new DM500 with alps tuner.
If possible i want to use an image with some sort of website browser,.,
cheers
ebmaster
Likes
Some moments of patience and inspiration i managed to install gemini 2.20 again after hydra and SF team made cry !
somehow managed to sort it out...chose the third option on start up of gemini. complex setup.
Now i have a another problem related to my wireless network :-(
Keep getting unknown error 2 when i try and download something. It was working before when the channels were not working...
I can connect ok from the PC and configuration look ok....
Any ideas...Do i need to re-install...???
