TV CABO is not going anywhere
EgyptDUDE
have a 2.40 m Amercian monster + truman Gold starsat + NeotionBox3000 + Mvision + DragonX
Egypt
yes
the keys for the Nagra2 is out , before the complete implementation of N2 and shutting down N1 , the keys for the n2 are known now , softcams and Dreamboxes are already running the package on N2
not its Polsat's turn
and down NAGRAVISION goes :-cheers
TV C*bo wasn't going anywhere. Since the N2 algorithim was cracked open, it was just a matter of time before software came out and of course, the keys.
Funny is they are still handling the turnover problem from N1 to N2 and the nextdoor neighbour changed to N2 in 2003. The even funnier part is when TV C*bo decided to do the switchover in September, the next month D+ was with thier pants down!
Keys are out for Dreambox & TD, so probably available for other boxes.
guys,
my experts tell me there is no solution yet to watch c*bo if you are a satellite viewer. Are they wrong? (I used to have a card for mirage900s but now its all gone). HELP...missing my football
C*bo is just fine on many receivers.. I personally have two FTA receivers, Clarke Tech 1500 and Pixx plus. TV c*bo N2 is working perfectly.
Magic card is gone on my mirage 900s. What can I do to watch cabo again? Has anyone managed to get it on mirage 900s since they've moved to N2? Thanks, guys
Depending on what firmware version(1.0 or 2.0), there are solutions for the 2.0 ver. of the 900s.
don't know where to check my firmware version! Where do I go to see that?
Sorry for the naive question but before I had a card and never had to do anything...
thanks or your help
thanks or your help
Check in the Portuguese section in receptores/Mirage. There are links to download sites also in the Portuguese section which can get you software for the Mirage 900. The loader DWSUv34 or the MirageUv1.1 which lets' you upgrade and load new software will tell you at the start of the upgrade what firmware version is your 900.
Are there any keys to get tv cabo on matrix reload? posta link if
there is one
i was thinking why isnt it possible to watch like prem*ere and po*sat with softcam if the nagra 2 algoritm is known?
Que precisas para mudar o firm? É muito complicado? Estou interessado em comprar um ClarkeTech FTA 1500, mas levo vários dias tentando encontrar algo na rede e só esta o firm original.
Graças por tua ajuda.
Uma saudação
