• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
TV Link audio problem
Likes
Sky
Spain
#1
I have just installed a TV Link to my sky box and the picture is fine and the remote works but we have got no sound on the second TV
Anyone got any ideas?
Leanne
Topper
Amo Amas Amant Admin
Likes
3,035
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Just a thought, if the 2nd TV is from Spain not the UK then it may be the incorrect version of Pal, but I may be very wrong
Looking at this chart Spain uses Pal B/G and UK pal I so could very well be the problem
Likes
Sky
Spain
#3
Topper, we brought the second tv from the UK, the sound doesn´t work on Spanish channels but I was hopin it would work on sky !
Leanne
Likes
1,252
#4
Sounds like the case Topper, you need PAL I for the sound from a Digibox. See if the TV has an option for PAL I in the sound menu.
Topper
Likes
3,035
#5
It depends on the TV but you may be able to alter the settings in the menu. If it has autosetup and you just connected using the terrestrial aerial then it may have auto switched to B/G but again I am only guessing it is however worth checking and even experimenting
Likes
1,252
#6
Sorry our replies crossed Leanne, it should work on a British TV, but still check the sound settings.
Topper
Likes
3,035
#7
Must learn to type faster and and the art of brevity:-rofl2
Likes
1,252
#8
Even worse, I only looked at the bottom post, so didn't see your answer. :-lmao. :)
Well nobody can say that we ignored Leanne's post. :)
Likes
Sky
Spain
#9
Thanks for all the replies guys! i´ve tried the sound menu with no luck, could it have anything to do with the cable ? I´m using the same kind as the one from the disk to the digibox
Leanne
Topper
Likes
3,035
#10
Just out of curiosity have you tried taking the portable over to the sky box and connecting using a scart then switching the TV to AV1, do you get sound then?
Likes
Sky
Spain
#12
Topper
Tried the scart plug and it had sound so I guess it must be the cable, thanks for your help
Leanne
Likes
1,252
#13
Can't see it being the cable Leanne, as the video and audio signal are sent to the TV in one lump (for want of a better description). :) It will either be the digibox malfunctioning, or the TV settings, have you got an English VCR there that you can check it with?
Likes
Sky
Spain
#14
Yep I've got a UK vcr, what should I do? what do I connect the tv link to?
Leanne
Likes
1,252
#15
Connect the TVlink to the VCR input, then connect the VCR by scart to the TV and select the AV channel on the VCR. If you have sound via the scart connection, then at least you know that it is the audio setting on the TV.
Likes
Sky
Spain
#16
YEAH, it worked !!!! The sound quality is not too great but at least it works
Thank you, Thank you, Thank you
Leanne
Likes
1,252
#17
Well done, particularly as I gave the wrong instructions above. :-lmao
I meant to say, tune the video to the Sky channel and select the AV channel on the TV. :-doh2
Topper
Likes
3,035
#18
Well Rolf having re-read this thread I do not think either of us should take up synchronised swimming :-rofl2
@Leanne, glad you finally got something sorted
Likes
1,252
#19
No chance, I couldn't stand that clip on my nose. :)
