uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
It is for now, but I wouldn't mind betting they will change it again just before Xmas.
If you have the right 'tools' I don't think it takes more than a matter of seconds to brute force the key. However, a lot of people who do aren't very keen on publishing as they see it as provoking the broadcasters into using something more secure.
Sent from my Nexus 4 using Tapatalk
Can you please tell me on "BBC One" on this mux, I assume 1830 is BBC News Channel, and also at 2225. BbC london at weekends and bank holidays.
But, what is carried at 1957 just before Eastenders? HD carries national news headlines, and in the local window, a national weather forecast is carried. is this what is on this channel.?
Also, can someone check at Breakfast time - is that also BBC News Channel for 15 minutes? Thanks.
Can someone please tell me is there any more new labels on that mux yet? Anything on BBC3 HD and CBBC HD?
Thanks. That I knew, but are you able to see this mux - see above post about local windows. Thanks.
No - most of the western arc is behind trees here, apart from 30w where Ive found one place where theres enough of a gap to get some signals through......
OK if anyone is able to check this after Eastenders please can you tell us what is in the loca window? Thanks.
jimbo, can you list exactly what you want to know as regards BBC One at 27.5W? Please specify days of the week and times.
I may be able to check that for you.
Please note there are several BBC One channels so be specific which one you want checked:
BBC One
BBC One HD
BBC One Scotland
BBC One Wales
BBC One Northern Ireland
Thanks very much for your help. Please see your inbox.
Thanks.
It is being reported elsewhere on this forum that CBeebies HD / BBC3 HD has started testing on 11023H (Astra 2F UK beam). Can anyone see any sign of them now also appearing here on Intelsat 907? I don't have access to my installation right now to check. Thanks.
they did appear on a scan a couple of weeks ago but i cant check now as im using my TM5302HD which refuses to even scan the transponder in even though the signal booms in here
Just scanned. They there alright but still with encrypted PMT which is a no go for me ...
anybody having signal problems tonight in canary islands.started at 10.pm
technomate 5402 and 1.2 meter dish,black ultra lnb
signal now around 58 percent have a picture and sound but have a no audio/video message in middle of the screen
No audio/video with a picture usually means there has been a change with the mapping on the mux. Try re-scanning
Won't help with scrambled PMTs. It could even destroy a working list..
