For Sale Unicorn 1.25m Prime Focus Dish on Jaeger 1224 Motor
I have for sale a Unicorn 1.25 metre prime focus dish and a Jaeger 1224 H-H motor. I am led to belive that the dish was UK manufactured by Rolls Royce for Unicorn Satellite Systems. It is a very high quality spun aluminium prime focus dish similar to Precision/Elite.
Unicorn PF Dish - Who Manufactured Them ?
The dish is in very good condition without any dents or dings to the reflector surface and is complete with feed support arms, feed holder and Ku C120 LNB adapter. The pictured Invacom multi output LNB is not included in the sale, however, I will include either an Invacom or Inverto C120 single output LNB. The Jaeger 1224 H-H motor is also in good condition and without any play in mechanism. It comes with the original adapter plate that is used to mount the Unicorn 1.25m dish.
Please note that the dish and motor are being sold together, not as separate items.
£400 collected, no offers
Location ~ 7 miles from J6/J7 of M25 in Surrey.
Also available at extra cost if required are:
1. v-box positioner for the Jaeger 1224 motor
2. Galvanised steel tripod ground stand (choice from two, one with 3" pole diameter, the other with 4" pole diameter)
3. Set of three pre-drilled concrete kerb stones with brass rawl bolts used for anchorage (dimensions of kerb stones are 3ft x 6" x 5")
Lazyonics
Tynemouth, UK
Pace MS1000
Yes, I would be interested, if you throw in the stand !
...James
...James
A stand will only be included at extra cost.
Both stands are original Precision Antennas galvanised ground stands and are superior to the paint finished tripod ground stand sold by SSS for £185.
I am not prepared to include a high quality galvanised ground stand with a Jeager 1244 motor and Unicorn prime focus dish for £400
s-band
Essex
@Lazyonics I've got a 2 1/2" dia x 1.5m high stand with ~340mm square, bolt down, base that you or anyone else can have free if collected (Essex). It's a bit rusty in places but sound.
Lazyonics
Tynemouth, UK
Pace MS1000
I know its been a while but did you sell it ?
Just getting time to get back into the hobby again...
No, it was not sold and is still here in operation, I use it as a backup dish if ever needed.
