Universal LNB for my old dish
fadshen
Hello All,
I have an old dish with elliptical shape (around 75cm x 65cm) and it has an old single freq. LNB with a shape similar to the one I put on "http://www.fad.esmartguy.com"
I am looking to buy a Universal LNB, which type should I look for? Bearing in mind that the old LNB is fixed to the dish's arm using a half circular ring which Clinch around the cylindrical bit of the LNB (this bit has an approximate diameter of 3 cm).
Many thanks,
Fady
Most common LNBs are 40mm collar, if you buy something like the MTI Blueline, you shouldn't go far wrong.
