UPDATED April 12th 2010 :- Sly UK Bouquets
skunk1111
dreambox 800hd
uk
i found by oping up a existing bouquet on my db500s and adding the list posted is the only way to get these settings on a db500s.
My db800hd took the bouquite straight away no probles.
No amount of engma 1 etc button pressing or reload commands will make this work on a db500s
wonder_lander
Sky+, SkyHD,TiVo,Windows Home Server
tomthebomb1968 said:
Lads you need to change the typeset to type 2 for enigma1 images and then save it again b4 you ftp it to the box
Sorry for the obvious question but where do you change the typeset in dreamboxedit?
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
Once you have loaded your settings click tools and its the last option
wonder_lander
Many thanks for that :D
Will have a play with changing the system type and re-uploading again.
wonder_lander
Just wanted to confirm all working after I changed the typeset!
Many thanks for the great bouquet and assistance in this thread!
hungabunga
Orbital 80cm Dish,
Inverto 'Black Series' 0.2dB Twin LNB,
Moteck DiSEqC 1.2 motor,
Dreambox 500s
manchester
I just uploaded these to my 500s and I can see all the bouquets etc but now my stored motor positions don't seem to work correctly. Is there a file which has the stored motor positions of manually found sats.
Sully
Oily
Satellite=Motorized Triax 88cm&a DM800HD with 500gb hd.Vu+ Duo
Radcliffe
Thanks for the channel list but is there any way of retaining the sly channel numbers as opposed to the dm's?
i.e sly BBC 1 is 101 but on the dm it's 1,just my missis knows the channels numbers off sly,i'm trying to get her to use the DM more :-thumbup
Edit,sorted it,just updated the Harmony One with some icons to make it easier for her!
wonder_lander
I too would like to know whether I can make the DM500S select the channels based on the numbers in the bouquet so 101 would take me to BBC1 or is the whole process just about grouping channels together?
Jaffacake
Dreambox DM800
Scotland
thanks for posting the sly uk listings, amazing.
having a problem with box office, whenever i watch a movie the film freezes (pauses) after a few mins, any ideas?
xavk
Dishes:
Triax110 fixed to 5,9,13,16,19. Sky mini dish with Octo LNB. Triax88 on TM2200 rotor with quad LNB
Receivers:
Dm800 (5,9,13,16,19,28+rotor), TM500, TM600, DM500 (all 13,19,28+rotor)
East London
Wouldnt it be possible to do this by adding in a "placeholder" bouquet full of 100 channels, then starting another bouquet with BBC to run from 101? Would need a placeholder for each gap in the Sky EPG, but I imagine it would be possible.
didineedthis
Dream Box DM800 / Vu+ Duo
B16MCC said:
BOUQUETS UPDATED
Changes include :-
Addition of Sly Box Office Channels.
(Some What Experimental - please report findings).
Addition of Sly Sports Active Bouquet.
Addition of ITV1 Regional Bouquet.
Addition of Adult Bouquet, not yet complete.
Enjoy.... :-thumbup
@B16MCC :-worship
Just installed this on a Virgin Brand new DM800 (original box)
all working sweet as a nut, many thanks, saved me hours of work sorting out my bouquets
Happy days :D
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
OK guys, having thought about what xavk was saying I thought I'd try it. If you make your first bouquet using the place holder entries the subsequent bouquets can remain as normal as the channel numbers are set by the first bouquet.
So, here's the Sly UK bouquets with place holders in the first bouquet to make the channel numbers match what they should be. So now you can select channels from the individual bouquets as always, but also BBC1 is now 101 and Sly Sports HD1 is 408 etc etc as they are in a sly box.
So thanks to xavk for the prod. Try em out it works very well.
leez
tm 9100 tm 1500 ci dm box 600 1 m dish polar mount 12 inc acuator v box 2 cas 3 dragon diablo gamma
england
can some nice person tell me how to import the sky bouquets through dreamedit to my dm 800 ..just got it and i can swap about and mke my own bouquets but cant seem to upload the sky bouquets many thanks..
xavk
Dishes:
Receivers:
East London
Extract the zip file to a convenient location on your HD, then from within Dreamboxedit, go to the Import menu (along the top) and select the Import User Bouquet Files. Point the dialogue box at the location you extracted the zip file to and you should be good to go.
Rricky
Dreambox 500s
uk
Can't see any setanta sports in the listings
B16MCC
/var/tuxbox/config
This is Sly UK , not ROI. If I remember I'll add them to the Ireland Variations bouquet next time.
Rricky
Dreambox 500s
uk
Rricky
Dreambox 500s
uk
Is there anyway for me to add these channels in with dreambox edit if so how ?
B16MCC
/var/tuxbox/config
Yes ofcourse. Have a look at the tutorial I wrote on DreamboxEdit. You'll find it in the Guides and Stickies section.
abdul.jabbar
tecknomate to next patched
uk
@B16MCC
Do you have fav list for other sats that you want to share.
When i download a list it usually loads but when i point to that sat i do not get any signal although all the channels seem to be present on the list.
But scanning the sat myself does not give me any issues. Your one fro sky worked great.
I can get from 45 east to 30 west
