urgent help needed
Storm55
Likes
Mondeal 7500 + Dragon cam. 1M moveable dish
DB500s
Torbay, Devon
#1
I have a problem with my db500s
I have loaded official image into box, configured complex diseque. and gone through the usual configuration. In satfind it will not lock on to satellite although the dish is spot on. When going back to the menu display always returns to No diseque selected. I have even tried to set up machine on 1 satellite only but it will still not lock on. Any ideas.
Tim.
Likes
Tim.
Unplug/replug the Dreambox. If that doesn't do it then try reloading the image again. I've had to do this a couple of times before and the reset worked for me as well as relaoding the image. Good luck!
Storm55
Likes
DB500s
Torbay, Devon
#3
Great thanks I will try this, I thought I had broken it.
Storm55
Likes
DB500s
Torbay, Devon
#4
Hi thanks for the above. the db is faulty apparantly the tuner circuit board has gone, and needs to be sent back to Germany, I have been advised that this will take up 3 months!. No wonder it has taken me 6 months and still not achieved anything,,
Tim.
whatsthis
Likes
DM7020 Screambox
MAC OSX & windowzz 98SE
Gemini
1664 on tap
13°E
#5
Just a quick question. How long did you wait after starting scan before aborting the search ?
When I'm searching for a lock on hispasat it takes about 2 minutes. For a long time I thought mine was broken.
Storm55
Likes
DB500s
Torbay, Devon
#6
Hi Icouldn't get that far I couldn't lock onto sat even though pointing at it. The opening box for Diseque set up kept reverting to no Diseque. As a last resort I am trying one more image, before sending it back.
Tim
john_graydon
Likes
Dublin....Ireland
#7
Tim
I would try a lot more than 1 image, try everyone.
whatsthis
Likes
DM7020 Screambox
Gemini
1664 on tap
13°E
#8
Hi Tim
Can I ask how do you know that your dish is spot on. Have you checked it with another box ?
With hard to find satellites I use a cheap FTA box (it's lighter up the ladders than a D:cool: and manually move the dish until I get a good signal. Only when I know its aligned do I connect the motor and the DB.
Let us know how you get on.
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#9
And are you using a sat-meter to find the strongest signal before trying to "tune" in that transponder?
Storm55
Likes
DB500s
Torbay, Devon
#10
Hi thanks for the reply.It appears I have been fighting a losing battle. I thought that I was suffering from fingure trouble, but the DB box is faulty. The circuit for Diseque control has failed, So apart from spending 6 months trying, I have now been told tit could take up to two months to be returned. I will have forgotton eveything I have learnt by then.
I am very disappointed with Dreambox in Germany as I emailed them asking for advice, and they didn;t bother to reply.
Regards
Tim.
