Pace Digibox locked on standby. A solution to this problem urgently will be rewarded.
PPV adult channel accessed briefly with telephone line disconnected. After a few minutes TV then switched to sky sports then switched back to PPV but this time pin number not re-entered. During this time phone line still disconnected. Sky box switched off at mains,phone line reconnected and then box switched on again.
Box is now locked on standby. Forced download tried unsuccessfully.
High pitched noise comes from back of box.
Should an engineer have to come out will they know the hidden menu has been activated or do the "television settings" as well as the other settings return to the original default settings after the box has been switched off at the mains for how long?
If an engineer were to find numbers entered thru a hidden menu what is the likely course of action?
thanx in anticipation
raymond
raymond
