USALS and sat positions at extreme east
L
Likvid
Likes
5
Stockholm, Sweden
#1
Don't know if this is normal or not but i have noticed that satellites to extreme eastern locations are a few degrees off.
Like Turksat 1C, the motor pass the correct position and miss it by 1 or 2 degree so i have to manually drive the motor back to the correct position.
Is this normal with USALS? all western satellites to extreme 45West isn't any problems, hit it on the spot.
The problem starts with extreme eastern satellites.
I've read in some other forums that other people have to nudge the motor a few degrees as it misses the correct position.
P
pothead13
Likes
Technomate 1500ci + 1000d super +
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
pc + laptop on network
uk
#2
i have the same prob as you been bugging me for weeks i just decided to not wory about as long getting signel on the sats i should get as it easy to save the sats i have to manually drive back.
maybe we need bigger dish for usals to hit the spot on all sats anyone know
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#3
Bigger the dish then tighter the beam. So no you need a smaller dish to correct for that, and who is going to swap to a smaller dish even if it is wider angle.
Think the easy solution is just to nudge it.
L.
L
Likvid
Likes
5
Stockholm, Sweden
#4
Hmm....so why have they introduced USALS if it doesn't work 100% correct?
I thought the idea was that it would go to the exact position for all sats, but in my case some doesn't do that and i have to nudge them a bit.
theboss4
theboss4
Likes
Dreambox 500s
80 cm dish
Humax 0.3 LNB
Motor
Lots of cable!
Crappy old 60cm, sometimes use it.
Norfolk, England, UK
#5
i have same problem, all sats are fine except 42 east, can't even get a strong signal if i nudge about, only get %42 on tv8 with technomate,0.3 humax lnb and 80cm dush.
I had problem with 30 west, but got that sorted.
All sats are fine except 42east.
P
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#6
so it is normal then to have to nudge it over
P
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#7
have you tried tweaking the dish on tv 8 with your best signel by moving didh up or down / fine tuning on dish see if improves it dont bend on the dish to hard though but it does help pulling on the dish from behide gently . bit hard to explain.
if you can improve signel on tv8 it should still be good signel on other sats or a improvent
theboss4
theboss4
Likes
Dreambox 500s
80 cm dish
Humax 0.3 LNB
Motor
Lots of cable!
#8
yeah, i'm gonna have another play about with it.
I'm the bloke you speak to on msn, you helped me setup.
P
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#9
o yeah lol
J
Jeff_19341
Just input Turksat as 40*east in your receiver, this should do the trick. Mine are all over the place but only by no more than +- 1/2 degree.
L
Likvid
Likes
5
Stockholm, Sweden
#11
One strange thing is that when i go in USALS meny and choose Panamsat 1 at 45 West it turns to about 20 East instead.
Why is that?
S
steffan_st
A bit enthusiastic
Likes
Gibertini OP 125 L, Smart Titanium lnb with CD-80 feedhorn, Moteck SG-2500, Azbox HD Premium+, some 5 meters of good quality coax
Sweden
#12
Why is that?
Probably a bug,had these problems myself before i changed to a fresh firmware in the Humax.
My motor went to 12 west instead of 12 east when it was supposed to go to Astra 2d.
P
pothead13
Likes
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
uk
#13
i have to put in 45 instead of 46 to get 42 e
L
Likvid
Likes
5
Stockholm, Sweden
#14
Should it be like this?
I have the exact same problem.
However i think Diseqc is pretty decent and much smoother than the old 36V motors where everything had to be done manually.
C
claasi
Likes
105 cm motor dish with 75E to 45 W - Openbox 820 CI
Germany- Munich
#15
Well I only speak for me here but what I did is after USALS went to the position I put in the "autofocus" of the receiver and the signal improved quite a bit. After that I saved the position with the save button and from there on USALS always went to the "saved" postion.
Up till now it is still working correct. I gave it a try again after we had some strong winds and there was just a slight signal improvement. But this could also be a little gear problem or that the satellite just moved a bit in space.
Generelly the stored position is always found on spot even after weeks for me here.
