I was running out of memory so I took rolf's advise and bought a USB memory stick Sandisk Cruzer Micro 1GB.
And since the USB connector was already used by a USB keyboard, I bought a USB 1.1 hub for four devices.
Then I started to read about how to format the stick and move the /var to it.
I read all the threads and posts, and I thought that I would use either Telnet or FlashWizard and see how it will go.
Fortunately, the Gemini 4.0 image took care of everything.
These are the steps:
Formatting
With the USB stick in, blue panel > Extras / Settings > USB-stik(Disk) formatting >
popup
Formatting USB Disk
Cruzer Micro
Start (Green Button)
Are you sure ?
Yes (Green Button)
Formatting USB Disk
Done in less than 1 minute !!!
Mount and var move
Extras / Settings > Var-Folder >
Move
from /var
To /var/mnt/usb/gemini/var
Are You sure you want to move this
/var
to
Yes (Green Button)
Restarted Enigma
After the box restarted, I noticed that the Var-Folder disappeared from the list.
The box worked as usual.
When I tried to add a large size plugin, I didn't get the error message about not enough memory.
When the download started, the bar showed only about 2% !!!!
USB Hub
Shutdown the box
Disconnected the USB stick and connected the USB 1.1 4-way hub
Then connected the USB stick and the keyboard USB plug into the hub
Switched on the box and both the stick and keyboard working as usual.
Formatting
popup
Formatting USB Disk
Cruzer Micro
Are you sure ?
Yes (Green Button)
Formatting USB Disk
Mount and var move
Move
from /var
/var
to
Yes (Green Button)
Restarted Enigma
USB Hub
Shutdown the box
