usb stick problem !!!!!!!!!!!!!!!!!!
takecare
hi everybody,
I have a usb 2.0 stick of 512mB and i keep trying to make it mounted on the box.
I did type the unix instructions found either on Klona dummy or dreambox-australia-tutorial but at the end :
- if i do reboot the dreambox usb stick is not mounted
- if i try to mount it myself it says nothing found in /etc/fstab
I tried to insert a new line in the file fstab for my stick but it could not be saved saying read only even if it has rw settings.
Can someone help me on this matter !!
(i even try to use flashwizard pro 4 to format or mount. format seems to work but problem to mount).
thank you all
NCD
(my firmware is the 1.08)
hahaha i found the solution !
mkdir /var/mnt
mkdir /var/mnt/usb
mount /dev/.../lun0/disc /var/mnt/usb
then i could download images with flash wizard 4 !! excellent !!
NCD
(my firmware is the 1.08)[/QUOTE]
