borderfox
- Jun 5, 2006
- Age
- 41
Skystar 2 PCI card;
Dreambox 7020S
2x Eagle Linux Boxes
Moteck motorised setup with 88cm dish.
Multi LNB bracket
- Ireland
My system is a daisy chain of 4way diseqc switches - leading to 8 way diseqc switches - leading to each (5) TV point in the house. Have Astra2 feeding seperately from its own dish with Octo into each of the 8 ways. Other torroidal dish feeds 1*W/19*E/16*E/13*E via 4 way into 8 way and into each TV point.
Parallel to the satellite setup above, I also have terrestrial feeds into each TV point. These go through an amplifier between aerial and each point - else it wouldnt work.
My question is this;
I want to make some preparations for a sky+ type receiver ie. a receiver that requires two inputs. Can I use diplexers on each 'terrestrial' cable run?
If so, any recommendation on what diplexer to use as have never used before.
Thanks in advance for any suggestions.
