Using remote control with 2 dreamboxes
lasbrisas17
dreambox 7020 with motorised 1.2M dish
Surrey UK
Folks, I'm thinking of getting a second dreambox which would be located in the same room. My concern is when changing channels the other box will change aswell, can anyone think of a solution to this.
I think that there is a solution in the setup.
You would need to use two remotes.
AS I have only one box, I didn't need this feature.
I will check this out tonight when I am back from work or perhaps you will get another reply with the explaination.
There was an interesting thread especially for DM remotes by B16MCC
Suggest to search for it.
