Hi folks,
I've done a search for the problem I'm having, and have come up with some info, but I'm not too sure how to approach it as I'm only a keen newbie. The problem I have is this:
Sky are no longer transmitting TVEi (Spanish TV), so am binning my Sky subscription and want to move my Sky mini-dish to another satellite. The info I have found is:
Sky broadcasts on Astra 28.2E (compass reading 152 degrees-ish).
TVEi broadcasts FTA on Hotbird 8 13E (compass reading 167 degrees)
Replaced the Sky Digibox box with a Goldstar one from a friend.
I thought it'd be easy... Before moving the dish to the new bearing, I plugged the Goldstar box in and could see the signal strength meter on the Goldstar box show 90% Quality, and 50% power - this is for the Astra reception. So shifted the dish horizontally to the new bearing and get 28% signal quality - stays at 28% wherever I move the dish to, so 28% means "I'm getting nothing". Tried making teenie-weenie movements from 28E right through to 10W or so, but don't get an increase in signal quality anywhere (apart from for the Astra satellite).
I've not moved the dish vertically at all, as I assumed that because all the satellites are geostationary, they're all at the equator and at the same altitude. Right/wrong?
I've seen people asking about LNB's - this is what is stuck on the arm in front of the dish to receive the signal - does that need changing for something specific?
I live on the south coast in Hampshire. Another assumption I made was that the Sky minidish is sufficient to receive the Hotbird signal. Even if it wasn't, I'd have thought I'd see a blip at least whilst moving the dish around?
Am I barking up the wrong tree (which remionds me, there are some trees in the direction of 13E, though nothing HUGE and leafy) or completely naive?
Thank you!
Thank you!
