Using white Sly card in dm800
deanoashtonio
n/a yet...
Derby
Hi there forgive me for the noob question.I need some help getting my sky card to work in my dm800 clone.i am using jade pli image and have cccam 2.1.3 installed. I have read the tutorial by B16 MCC and got as far as this.... i have worked out my boxkey and have used two methods of working it out,both come out the same, so i am sure this is right.
I have entered cccam.cfg in dreambox control centre on the first line i have this
BOXKEY: /dev/sci0 ** ** ** **
then after that is all the text from cccam team
in the tutorial it says specify the reader but what line do i write this on? what do i write?is there anything else i need to do?
i am totally new to this so any help is much appreciated
sci0 is the internal reader in your 800 so if you have the card in there and your boxkey is correct it should be working. If you are clearing some channels but not the premium ones then your boxkey is incorrect. If your only clearing FTA then start again from the begining. You say you have CCcam installed but have you switched it on? I cant remember the procedure for PLi but look for a menu something like "Softcam Settings"
