Vertical Channel problems
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
Using: 85cm penta, smart titamium 0.2 (few year old), eagle box.
All of a sudden I have a problem on vertical channels. Now and again there will be no signal at all, then a few minutes later the channels will appear with a booming signal. This happens on powerful satellites too. Horzontal channels are no problem.
Would I be right in saying this could well be my LNB ?
Thanks in advance
Well, you could check out what happens with one of your other receivers as it could also be a receiver fault. Also check your connections of course.
definatly my LNB. Tried another one and no problems.
Looks like I am going to buy another smart titanium
Good choice - I've a single output and a twin output Smart Titanium. Nice all round performer.
yes....cheapest as well....0.1db smart tit for under 10 uk pounds
I have this problem with TV1000
Works sometimes and then, suddenly, it´s gone.
Changed LNB No joy, tested with a new decoder same story (after a while so You noticed it - it happens not all the time). So I checked the cable, the switch and took a trip up to the dish to re-install it again.
Still having that strange problem....
