haggard
- Sep 6, 2004
7000S - 300GB Maxtor
1GB USB -
Syslink wifi bridge from DB to Syslink wifi router to Apple Extreme streaming relay to Apple G5, 2 xG4.
Elgato into G4 17 in for Apple DVB-T captures.
Panasonic 42 HD ready
- NW England
Just one comment, if you go the route I do, via a dv (avi) file then using a mpegger like Bitvice, you can clean up the picture quite a bit and it looks subjectively, just a tad better than the original VHS tape. On my trusty old panasonic VCR, there is a little knob that takes out noise. That helps if I am in a hurry. But Bitvice has algorithms looking for areas of uniform colour/density and does a good clean up.mhku said:Yes, the results are the same quality as the original tape. The VCR connects to the Adaptec box, and then to the PC. It records in realtime (Sonic DVD is the software) and then "writes" the file as an mpg to the hard-drive (and that's the part that may take time on a slow pc). I then use Nero to make the DVD.
You can see all the ways to do it at www.videohelp.com
You need plenty of RAM though. My box was £30 off ebay, £6 for the lead.
And then I bought 2Gb of RAM ;) otherwise your PC will be unuseable during processing.
Referring to the original need - cheap, I would look for a Hollywood Dazzle on eBay or look at current new version (VCR -> dv). It must be less than £100.
I cant remember what the name of the VCR -> mpeg gizmo was in MediMax but Do wohnst in Deutschland nicht? T_G? Then there must be a store near you
h**p://www.medimax.de/htms/filialen/f_filial.html
I have a hauppauge digitiser also that I got when it was the only thing that would work on a Mac. I hardly used it on my G3 cos there was always a faint warble on the audio, something to do with the USB multiplexing. I used it only for making movies off VHS to watch on trains where the warble couldnt be heard. I will check it on new G4 and see if the warble has gone. Hauppauge simply said "what warble" -- except in web archives (you cant escape them) there is a link to an old Hauppauge page saying their engineers were looking into it.
If there's no warble, you can have it for price of postage. If warble is still there, then I will bin it. It is possible drivers exist for PC.
I used to capture using Adobe Premiere which saw the thing alright on Mac.
