Volunteers needed for a Special Project
HB13DISH
Retired Mod
Middle East - Israel
rolfw said:
What do you want us to do if there are channels not on the list, add a line?
Please leave them. I will add them in my final list. :)
easysat
Dreambox 7000S + motorised 80cm dish, Amstrad DRX550 Digibox + fixed dish
pj::
I can spare 30 minutes to help fill in some channels if needed.
HB13DISH
Retired Mod
Thanks easysat. :)
It will take a bit longer I am afraid.
HB, with my TD, I noticed that some encrypted channels readily found the video bitrate, but not the audios. Does the Dreambox find them?
HB13DISH
Retired Mod
Yes. I will fill them in.:)
Thanks. If I'd thought about it at the time, I could've used TSReader on my DVB PC card for those, as it has all the info.
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
A small problem here mate. I'm on a DM7025 I don't get the same plugin list as other boxes. The bitrate viewer is not on my list. If you know its available for 7025, then I'm more than happy to get it installed and help the project. I checked IHAD but its not there.
I've just realised there's similar util already in blue panel, system info, stream traffic. This does show me a video and audio bit rate, however the video moves a lot. Am I right in thinking your plugin gives you an average value. The value I see can move over 800kbit in a couple of seconds. Its almost impossible to record it.
Any suggestions ?
Regards
MCC
flashgordon1952
sky amstrad and panasonic systems 6 pack setup. two 42cm dishes.just ordered a technomate 6900HD with motorised system one metre dish. also at another address.twin feed static 80 mm dish non digital system. 6 year old dell with server memory 680 of
essex in the wilds somewhere
if i had a dreambox now i would have helped.considering i only work 4 hours a day and semi retired now. But i dont think i could handle a dreambox. anyway with the linix system sounds a bit complicated. Anyway my TM6900 HD gets delivered on saturday. think i going to have my hands full with this. i assume the dreambox is the only reciever that can show bitrate ! i wish the forum members who are helping the best. i think they are doing a great job well done boys!!
HB13DISH
Retired Mod
Any suggestions ?
Regards
MCC
There is probably a good reason why it is not on the list.
I don't think that it would be a good idea to install a plugin that might not be suitable for your box.
Thanks for your offer to help.:)
I didn't like the stream traffic monitor in the past. This is why I used the plugin instead. Gives four values as shown in post #1
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Here is my list. Unfortunately I could not find many statios, even though I scanned the sat and the frequencies. I suspect that they euther have diferent names or that these are old stations not in use any more. TG.
HB13DISH
Retired Mod
Thanks T_G. :)
Especially on this special day. :-worship:-worship:-worship
I took the list from Eutelsat website instead of my box's channels list thinking that they are up to date. But don't worry, I will give a complete list in the end.
Heres my contribution - theres some of them missing / closed, I cant find some of them, and theres some new ones started, but Ive done me best with it :)
  • Hot Bird 13E Channels List 100308 For Analoguesat.zip
HB13DISH
Retired Mod
Thanks Analoguesat. :)
It is great to have such a wonderful team effort. :-worship:-worship:-worship
It might be worth doing the same study on 28E when this one is finished - name and shame the channels with unacceptably low bit rates (are you listening ITV? :D )
EDit - its already done:
_http://www.linowsat.com/0282/all/0282.shtml
