AncientRocks78
- VU+ UNO 4K SE 1xDual DVB-S2X Multistream Tuner, 258GB TEAM SSD. HP ENGAGE MINI 10th Gen i5 10500T, 24GB RAM 2666MHz SKHYNIX, 2x 258GB NVME + 500GB HDD, Win10, Win11
- Morocco, Casablanca
Hi everybody, i hope everything goes well
I recently bought a vu+ uno 4k se, a used one second hand in like new condition. Everything looks good, no scratches on screen or the shroud, but my only problem is the temperature.
When i watch the HD-FHD channels the temperature is between 64/69 degrees, now when i’m watching the UHD channels, the temperature goes between 71/76 degrees, and i was suspicious about that.
So today, i have disassembled the receiver to check whether the heatsink or the thermal pad was still placed correctly and in good conditions, but when i unscrewed the heatsink and removed it back from the motherboard, the thermal pad broke. So i went to a local store, and picked a thermal grizzly minus pad 8 (30x30x1.0mm), replaced everything back to like it was, and checked everything is well placed, powered on the receiver, and after approximately 15 minutes, the temperature goes between 65/70 degrees.
Please guys, is the 1.0 mm thickness of the thermal pad a right choice? And is there any good cooling solution or either a replacement heatsink for the VU+ UNO 4K SE?
