Wall Mount 60cm dish
sat-new
Currently Nothing.
Hi Guys, I am moving my 60cm dish from a wooden post to be wall mounted, I have a wall bracket (similar to part number A30FB from maplin, its not that exact one but very similar). The question is which size/type of bolts should I use for this?? I was thinking of 4 M8x80mm sleeve anchor bolts, but im not sure if this is too much or too little. Obviously I want to be sure it is a good strong fit, so I want the best possible. Also, any tips on securing the wall mount would be great, specifically should if be protecting the holes in anyway? silicone or something??? Thanks in advance p.s. Sorry if this has been asked before, I have searched but didnt find anything about a smaller dish, just 1mtr and above.
It depends what its being fixed into, if the bricks are good, for a small dish like that, you would be able to use M8 coachbolts and rawlplugs, no problem.
The sleeve anchors are better though, but usually not strictly necessary.
