wall Mount
den123
ddcccccc
uk
what size bolts do i need to bolt it to the wall and what sort
wod
yorkshire
well i used 8cm long 10mm sleeve anchor bolt from b&q which has held mine up for over a year now without any problem
R
Rd100
Hold what to the wall:confused:confused hanging basket, basketball ring, hose pipe holder, gate ??????:confused
satelliteman
East Midlands, UK & Lanzarote, Canary Islands
Assume your referring to your 1M dish & Moteck Motor.
Use a pair of T&K brackets and M8 / 60mm anchor bolts will be fine (drill size 14mm). You can use M10's also but be prepared to drill several 16mm holes :D
SM :)
den123
ddcccccc
uk
thanks to you all will do that
