Terryl
- OpenBox X5 on a 1 meter motorized dish.
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
OK just as the title says, water cooling....Do I need it?
Well it all depends on what your trying to do, if your a gamer then it may be a good idea, as some gaming PC's get quit hot, or if you do a ton of data processing, or handle and do a lot of video data it also would help.
The first thing to do is see if your computer's motherboard has any sort of CPU temperature indicators, I use Intel motherboards, they come with software and hardware to monitor the CPU temperatures.
The more data you crunch the hotter the CPU can get, most systems come with a standard CPU heat-sink and fan, in some cases this stock fan and heat-sink may not be enough to cool the system's CPU, when the CPU gets too hot it may slow down or even lock up.
Adding extra fans or a bigger CPU heat-sink can help, it all depends on what your doing with that system.
A standard water cooling setup would consist of a water block for the CPU, this replaces the fan and heat-sink, a pump to move the water around and a heat exchanger, this could be a passive one that uses convection to cool the water, or a fan assisted radiator like in a car or truck, and tubing to pass water back and forth.
Other items would be a water reservoir or expansion tank to hold more water, (it does over time evaporate) a flow indicator, (tells you that something is amiss, like a lack of water) and temperature sensors.
So lets look at the individual items.
First the CPU water block.
There are many types available for many types and brands of CPU's, I would not go with a cheap one as if it leaks your mother board could be ruined beyond repair. (I had one leak, it was covered under a warranty not to leak, so I got a new mother board)
Now these may also come with different sizes of hose options, it all depends on how much heat you need to dissipate, I went with 1/2 inch (12.7 mm) connectors and tubing, this kept things real cool even during the summer heat.(water cooled server is in the garage, it is a bit noisy)
The better water blocks can come with a pure copper CPU contact surface, some of the bigger $$$ ones can come with a silver CPU contact block, these cost a bit.(I went with the copper)
If your into the internal lighting of the case then some even come with LED lighting.
