weak signal on sirrus
O
ooktar
I can receive all tp's on sirrus 5E with almost 100% except Viasat packet TP's (11881H, 11977V, 11996H, 12034H, 12054V) These are 10% and no channel. Is it possible? What can be the problem?
Thanks...
w hole
uk
where are you Ooktar ?
regards
w hole
2old4this
Honorary Admin
Cloud Cuckoo Land
North West of Turkey ?!
No wonder.
I think you are too far oustide the main footprint my friend, unless you have a dish the size of a planet.
The package you mention transmits at lower power I believe, as I know others with problems receiving those signals. I can receive them perfectly from my location (the Netherlands).
See here for the footprint:
http://www.nsab.se/satellites/sirius3cov.html
http://www.SatcoDX-op.com/SIR/eng/coverage.cgi?SIR003KN
2old
Crapz
Computer with a Hauppauge WinTV-NOVA-CI-S PCI Satelit-TV
Viasat
Denmark
i almost have the same problem :D
i'm in Denmark and i can't tune any channels on sirrus 5E 12034 H 27500
i can tune all the others channels on
sirrus 5E.
any help ?
//crapz
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
i think 12034-H-27500 is a fairly weak signal i get 35% from nw england with 1 mtr dish
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
OK here in My loc with a 1.25mtr.
L.:)
In Denmark it should be knocking your dish over. :)
Can you borrow another receiver and try it? If not, although the frequency isn't a match, have you got a DECT phone nearby?
PS. Nice to see a five year old thread return from the grave. :) :-lmao
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
does age matter he obviously found by searching which i think is very commendable:)
I agree, wasn't complaining B. :)
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
Rd100 said:
Are you ueing a skystar2 i was thinking about getting one of them
look at lancelots profile
he uses ss1 not 2
alert thread hyjack:-doh! (culprit me)
