Webro 125 cable makes no Difference!
TJExcalibur
Southern England
I used the original Webro 125 cable from my previous setup and ran a new Webro 100 cable. I was expecting a stronger signal from the 125 but there is no difference. Now if I had known that before I would have used Webro 100 as its and more flexible.
What length is the run?
20 metres, give or take a metre.
For 20m, 125 cable is not necessary, the attenuation difference is neglible at about a one dB.
Certainly no need for a 20Mtr run.
Thats it then. A big seller of satellite equipment told me a couple of years ago thats its best to use 125. Ah well, I suppose they had surplus stock.:)
It is better of course, but with satellite reception you might notice a difference on one particular low symbol rate transmission on a low powered satellite on one specific frequency.
As things progress towards MPEG-4 and beyond you will find that cable comes in handy
