Whats my problem TPS?
Samba65
Is tps out right now? I have updated my humax 5400 with the new key bin file and nothing. I have also tried using a fun card with 6 in 1 file which works also but this time nothing. Any ideas?
LANCEofIRAQ what do you mean edit key 03? I don't think TPS has such a key. The only keys I know are ************** Is 03 a new key? If so where can I find it?
KEYS REMOVED BY ADMIN. Totally against the rules.
TPS should still work, although Multivision seems to be down for the time being. According to the Dr Hans website, theres been an encryption change with viaccess 015000 discontinued on MV.
hi so does that mean multivison has gone of or can we expect it back any time soon i know they have just opened up cartoon network on 10949(v) in english not sure how long this will be on went of last time pretty dam quick
Multi's still working on Dreambox Camd3.
yer mine is working when it's ad's!! as soon as the film starts it all goes of it's a mondeal box with a embeded cam and about 6 months old i fit sat's in lanzarote but i only use topfield box's and t rex cam's and fit sky and only deal with hispa so i have no idea with hotbird so i have no idea with a embeded cam so any ideas how to get my multivision's back on for me lodger please
Mine's working OK. Stopped working a day or two ago, downloaded new emulator yesterday and TPS / MV all OK. It's not enough to just update the keys.
Works here.. just watched a film on it..
works with MRV and MR
You dont know what you got till its gone :)
NickCY said:
LANCEofIRAQ what do you mean edit key 03? I don't think TPS has such a key. The only keys I know are xxxxxxxxxxxxxxxxxxxx. Is 03 a new key? If so where can I find it?
I mean AES key
1st time it is was 01 with 32 step code .
Now it's 03 with 32 step code .
Even that all id you wrote use 16 step code .
If you didn't see this key , how did you see Multivision before ??
_http://www.rdi-sat.com/viaccess.php
xx ant xx said:
how can i go about putting the emulator on my mondeal box
There is a mondeal file site listed Here
Multivision working with Via1_2funcard091105 file from sat-key on icecrypt black/echostar DSB808. If thats of use to anyone!
NickCY
do you know more about Star sat receiver that you are wiling to share whith me. I will be more than happy to have it especialy regarding nagarision .viaccess . biss and connax for hispassat and tps
thanks
my e-mail is dont post it here.com
This is one of our suggestions in the rules
It is also advised (for your own security), that you do not post E-mail addresses in open forum
Edited by Admin.
I understand that TPS keys 3 & 13 = TPS AES keys
key 3 is not new but 13 is.
Salvador
