which DB (please help need TV)
J
jankoh
Likes
I'am new to digital satelite TV. I was doing a lot of research but there is to much of info to read it all. So please help me out:
Which DB should I buy the DM5620 or DM500?
Which image should I use? What chanels can I watch?
Does FTA work with stock DM?
Thanx!
H
haggard
Likes
7000S - 300GB Maxtor
1GB USB -
Syslink wifi bridge from DB to Syslink wifi router to Apple Extreme streaming relay to Apple G5, 2 xG4.
Elgato into G4 17 in for Apple DVB-T captures.
Panasonic 42 HD ready
NW England
#2
jankoh said:
Thanx!
Dear Jankoh
If you are new to sat TV then there are some other questions to ask and answer first.
Are you new to PCs as well?
Can you configure a LAN and ftp files to the correct directories in a Linux environment?
If you downloaded a binary file, would you know how to change the permissions to make sure it is executable (chmod?.
Learning to use the D/B is a very fast process. You will scratch your head at times but there are a lot of people to help.
You don't have to be slick at the above PC stuff, but it helps. Otherwise a D/B might not be the right receiver.
But here's the first question 4 U to answer: why isnt the 7000 in your list?
J
jankoh
Likes
I know a litle bit about PC's. I'm a PC software develpoer and study electrical engeenering so the PC staff will not be a problem.
The DB7000 is a litle bit expensive and I need no HDD in the receiver. I read that I can "share" the HDD in my PC to save staff to it....
I'm wondering if there is any SW for DM500 & DM5620 or is all the hacking about the DB7000?
Likes
1,299
#4
Have a look through T_Gs posts in this section, he has the 5620 and seems to find an ample choice of software and plugins.
T_G
T_G
The Consumate Dreamer
Likes
215
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
#5
Yes I have!
J
jankoh
Likes
Hm, what about the DM500. I have to say that design or size doesent matter.
H
haggard
Likes
1GB USB -
NW England
#7
jankoh said:
Hm, what about the DM500. I have to say that . . . snip . . . size doesent matter.
yes it does
J
jankoh
Likes
OK I ment I have enougt place and the look of the box doesnt matter to me.
I'm looking for the better solotion. I know that the DM500 has a extern PS. Has the DM5620 heat problems?
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#9
The 5620 doesn't have support for internal hard drive so no heat problem.
J
jankoh
Likes
Does anybodie know the ram amount of the DB500. Dreamedia has no spec??
H
haggard
Likes
1GB USB -
NW England
#11
Isnt there a review in this months Wotsat?
ram size might be beyond them.
Likes
1,299
#12
You can pretty much guarantee that it will be similar to the other models, they all seem to be variations on a theme. What i would add though, there is little support for the new model currently, so may be better going for the very slightly older 5620.
J
jankoh
Likes
Yes. I'll go for the DB5620. It offers (up to) 64MB (the 500 is only 32M:cool: two SCART ports, and two CI slots...
