The C-band Norsat needs a WR75 flanged feed horn.
You need something like a Chaparral feed horn (
www.chaparral.net) or similar to mate to the LNB.
However, the fit of these depends on what dish you are using. The Chaparral feedhorns are primarily intended for (prime-focus) dishes with an f/D of about 0.3-0.4, whereas most offset dishes are 0.5 and higher.
Prodeling and Skyware Global makes feedhorns for WR-75, for example
http://www.skywareglobal.com/images/pdf/C-band_RxO_Feed.pdf
What dish are you using?
