Advice Needed Which is better for multi satellite reception?
daro2096
No setup at present
Consett, Durham
Wideband LNBs connected to two Inverto Unicable multi switches for FBC or Quattro LNBs connected to a multi switch such as a 17 in 32 out?
How many satellite are you trying to view???
I would suggest a single LNB with a dual output for each satellite, this unless the satellites are very close to each other.(5 degrees or less)
And why a 32 output switch?
4 satellites, 28.2, 19.2, 13 and 9 east. the multi switch is just an example. 16 outputs is probably overkill. The difference in price between the two is only £50 or so.
Well the spacing between 13 and 9 may be a bit tight, but 4 dual output LNB's (one output for each transponder polarity) would work , and I forgot to ask how many receivers???
Also a good elliptical dish would help, as your looking at a 20 degree beam-spread.
Am looking at the Big Bisat dish and the Vu+ Ultimo 4K receiver so up to 6 tuners if I go quarto route or up to 18 if I go the FBC route though am worried if I go the FBC route if I record a channel on 28.2 I will be limited to 1 satellite at a time. Also might want to add a second receiver at a later date.
Or I might go with just two Inverto Unicable LNBs for Freesat and Hotbird on a bog standard 60 or 80cm dish and run two cables to the receiver. I haven't decided yet. That would be a much cheaper option.
