- May 1, 1999
- Technomate 5402 HD M2 Ci, DM7000s, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Promax HD Ranger+ spectrum analyser.
- Berkshire
Rd100 said:Yes the lnb would have been ok if you did earth it, If some one else installed the dish for you you can claim a replacement lnb from them as the installation was not done correct,
All lnb feeds cables should be eathed useing a ground block,
I disagree there RD, as the LNB would be wiped out before anything got to the earth bond, that is simply there to offer marginal protection to the inside equipment.
