will not give up
  • Thread starter Thread starter tuasat
  • Start date Start date
T
tuasat
I have read AutoUpdate / How Does It works and the Eurocryp document but still do not understand many things. I will try again over this weekend.
I wonder if I can use this shortcut, just borrow a normal working smart card (pirated one that auotoupdatable) from a friend and read, copy and programme it to my Gold card.
Neu2Sat
it is an easy matter to read out the contents of the pic & eeprom on a pirate goldwafer card. First read the contents of the PIC. Then reprogram the PIC with a loader, which gives access to the eerpom. Then read the eeprom, and put back the original contents of the pic.
Then put the read-out files onto your other wafer in the usual way.
2old
some PICs can have their protection removed (check out the optins in your PIC programming utilities - look for PIC "bust" options etc.)
2old
2old, which PIC programming utility can allow this option to "bust" the PIC and thus enabling to read the "protected" PIC.
i have checked in picprog, icprog, pic card etc. but couldn't find them.
also can you post a link or email me Card master 2000 ?
thanks
jimmi
A bust-PIC option exists for example in the "pic24c13" utility downloadable at Willem Kloosterhuis' site: http://www.willem.org/
Direct link: http://www.willem.org/ZIP/pic24c13.zip
Also in the "Gold" utility at the Digital FreeSat site: http://www.digitfreesat.cjb.net/
Look in the "softhard" section.
Here is the direct URL: http://digilander.iol.it/digitalfreesat/pic/gold.zip
although it may be that the bust PIC works only for the older 16c84 PICs (I read that somewhere). Anyway, try it.
CardMagic-2000 can also be found at the Digital FreeSat site
Direct URL:
http://195.130.225.73/dfsfiles/software/cm2000.zip
2old
thanks 2old for your reply, and as always the best help we can find.
for the "bust" utility, i was talking about PIC 16F84 . do you think gold software etc. can work on this as well ?
is card magic the new name for card master ?
thanks again.
jimmi
Oops, sorry, obviously NOT the best help... I mis-read your request....
CardMaster and CardMagic are NOT the same thing.
CardMaster2000 you can find via Digital FreeSat too.
Here the direct link:
http://195.130.225.73/dfsat_files/software/cardmaster2000.zip
2old
I have the Multiprogrammer from Adteknik. Can I use the device and its software -- Multiprogrammer 6 to copy a pirated card?
Copy from: pirated golf card
Write to: PIC 16X84 card
Thanks.
Neu2Sat
The MP6 or "Elvis" is a very versatile, easy to use programmer.
Program's pic16f84/24c16 cards no problem. A full manual can be found @ -:
http://www.adteknik.se/english/manual.html
Zansi.
If the copying is successful, will the new card autoupdatable too?
By the way, my recent downloaded Multiprogrammer 6 doesn't work with the hardware I have. Only Multiprogrammer 5.93 works.
How do I determine the type of card that I borrow from a friend?
ISO7, ISO3, RB7? I am afraid to destroy the data, if I use Autodetect function to find out!
Thanks.
Neu2Sat
