wireless access point
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
I also have a little query that maybe someone can sort out. I have my wireless router hard wired to my dreambox via ethernet cable in my living room and have USB dongles on all the computers in the house to access the net, I find this works very well for me. What i want is to put my second Dreambox in the sitting room and have it on the home network also, was thinking I could share my local card from the living room to it. I have a spare wirelees router at hand, can this be configured to work as a wireless access point to talk to my original router?
harpdog
yes alsong as your cs network is configured properly. since i do not know your provider I canot tell u what card sharing config to use. do a search here for cardsharing+provider card type
tomthebomb1968
Thanks for your reply m8,I will be using cccam but I think i will be able to sort out that end, what do I need to do to my 2nd wireless router to make it a wireless access point? Cheers
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Just put that into Google and U will find some good ideas :)
tomthebomb1968
Google seems to be a lot of big contridictions, some saying it can be done easily, some saying it cant, and some others saying it can be done but only with certain routers. Has anyone done it? I have tried configuring my spare wireless router exactly as the one in use but no joy as yet. The spare is a Zyxel P-660HW-T1 and the one in use is one bundled fom S*y. I am convinced it can be done and will post the method if sucessful, as I think a lot of people could be interested in doing this.
pgh13
Midlands UK
Here are a couple of Netgear tutorials.
_http://kbserver.netgear.com/kb_web_files/n101236.asp
Using a router as a wireless access point is usually taken to mean wiring the 2 together to extend the wireless range
What you want to do needs a router that supports bridging.... see here
_http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=282034&action_code=5&highlight_info=16777291,3,5&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101503.asp&answer_id=17359694#__highlight
tomthebomb1968
:-bighappy
Got it sorted, well my m8 did it for me. Used the info from here. He used the practical example and not the instructions.
_http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
