wireless replacement for serial cables ??
D
dmm
Likes
hi
anyone comes across any devices which would do away with the need for serial leads / cables and so you could program your serial card programmers , connect to sat receivers or whatever purely wirelessly either using a wireless usb dongle or wireless serial device type setup ?
do you know of any hardware can do this including wireless simulation of a null modem cable ?
this site is kind of what im after but it suggest you need a separate power supply ?
_http://www.aircable.net
http://www.satdudez-forumz.com/forum/showthread.php?p=8737961#
