rolfw said:
Well it isn't only H/V switching, but also High/Low, so whilst I guess that if someone threw enough money at a solution and had power available at the dish, then they could work something out, but it would be very expensive.
Better and cheaper to build a littl insulated box for the receiver and use a video sender to transmit the digibox output back to the house.
Thats right, we did just that at a sight where we could not get the signal because of a rather high mountain. So get this:
Distance to dish: ca 3.7km. At the dishsite a plastic box for mains electrics 80x80x40cm. Inside this box a digital receiver,powered by 12V,a 95A Car Batterie and a 12V Videosender System with receiver for the infrared remote. The Antenna of this 2.4Ghz System got replaced by a 75cm prime focus parabol and a microwave antenna where the LNB used to be.(self made). Also at the site the normal dish,1.2m motorised via diseqe and a 50W solarpanel to power the whole thing.
At the receiving end again a parabol with microwave antenna connected to the receiver of the videosender system and of course the remote.
It works perfectly well and is also, after moving the receiving antenna and reallining the system,not interfearing anymore with our 1Gb Broadband, also coming wireless over 5.5km, but thats another story.
The things you have to do, living in the hills...........
Greetings
Chris
