Hi
i am new to this. just installed and set up the VU+. I have looked at compatible dongles and i purchased this 050D:935B Belkin Components F6D4050 N150 Enhanced Wireless Network Adapter v2000 [Ralink RT3070
when i put it in usb slot and navigate to network connections its showing not connected.
Am i suppose to configure/install something? i got to the network wizard and selected yes to both DHCP and USE INTERFACE. but nothing shoes in the current settings?
am i missing something. I have also installed some ralink drivers but none of these worked
also on some channels the speech is out of sync? any ideas>
i have blackhole 7.2.1 version Feb 4 2012-vuplus_experimental installed
thanks
thanks
