Wrong Cables for Dish
Dapo
Sky +
Freesat (inbuilt in Panasonic TV)
Essex
Hi Guys,
Newbie here needs help.
I have a quad LNB and it previously had two feeds leaving it into my Sky+
I have bought a new TV with inbuilt Freesat and decided to use the two remaining slots on the LNB, one for my Freesat and one for another sky box in my kids room.
I bought a new twin cable and ran it from the LNB but now the two new cables are not giving any signal!
what have I done wrong? Is it possible to buy the wrong cable? The other cables are outputting Sky signals as normal.
Could have added the f connectors wrong? I just screwed them on.
This is the cable I bought: http://www.tlc-direct.co.uk/Products/CAPF2100B.html
Please help. Thanks
Welcome,
Cables fine - Most probably a cable connection problem. Swap the feeds with the others ports on the LNb to see.
I basically did what is shown in those pixs.
I may revisit them and see if I have any braid touching the inner
should the inner protrude well past the f connector?
I will also try swapping around the feeds to see if it is just the LNB ports.
I'll let you know how I get on, will be trying again this Saturday.
2 or 3mm protusion roughly.
Robbo,
Thanks.
I have not had the time to fix my dish but plan to this week.
will be back with feedback.
