xcam 102 help
dad
can you give an old man some help please.
I have just got a xcam with 102 on it
how do i upgrade it.
Whats the first thing i must do and how to do it try and keep it simple its all
new to me.Seen a lot of threads about xcam but dont no where to begin.
Thancks. Dad.
Have you got the loader Dad?
Hi Rolfw
sorry rolfw dont have a loader dont no what it is.Do i need one to program
xcam if so what loader is it.Thanks. Dad.
It's a card with a serial connector. You can of course update the keys by using the remote control, but for the main software you do need the loader.
Thanks Rolfw
are all loaders the same whats the best to get.
sorry got to go now look out for u 2morrow. Dad.
Just added a picture of the loader above. :)
No, it is the dedicated X-CAM loader.
hi rolfw
dad again not to sure what type of loader to get.
Ucas loader 1.3 or emulator 1 or 2 or logger+emulater will any of them do the job.Or can you tell me where to order one from and what to ask for.
Thanks for your time. Dad
Hi Dad, get hold of a clanzer mr loader card, easy to use and reasonable price, only problem I found is getting it to work on the com port on my pc
Hi, I have bought the same programmer but can't get it to work :-(
What cable do you use to connect to the CAM? A null cable or a serial cable?
Thanks in advance!
