ryvm said:At last i have my cas2 interface.
This is what i see when i press connect :
CAM Connected
Xilinx XC9536XL CPLD Version 4 detected
Searching for flash...
Functionality not warranted
Flash unknown: Manufacturer ID: 0x90 Device ID: 0xC2
Grtz Rein
bonami said:I HAVE THE SEEM PROBLEM DID YOU FOUND A SOLUTION FOR YOUR MCR ?
trappa said:i have a "fortecstar magic world plus" receiver with embedded matrix (i have alredy upgraded it to mrv2.16 using fun cards)
i can update the matrix embedded only using fun cards but the problem is:
the mrv2.16 doesn't support card read
so if it's possible: i can update it using the serial connector found in the back side of the receiver
i just need a matrix loader that can upload bin files to my receiver!!!
i have the mrv2.19 binary file but i dont have the appropriate loader to transfer it to the stb!!!
pls help
mail:
kaisounovsky*yahoo.fr
Great greatneil306 said:use this m8 works 100% read the read me
MrFreeze said:hi, you can try matrix DN here : http://www.uploadfly.com
module area-> matrix rev/rel
i have not tested but it might work :-)
