Some Forums Not Working
chris
TalkTalk TV
Worksop UK
I've been moving the web site over to a new server the past few days, this should now make the site faster to load. I still have some data to move over for some forums so if you get a "SCRIPT ERROR" dont worry! its just that i'm still uploading the data.
You can now post to any working forums!!!
thanks
chris
autosat
Chris8
Hows it going with the irdeto forum, do you have any idea when this might be back up and running.
autosat
Nickolai
Chris,
I cannot login into discussion forum from home at all - the main difference is that I have IE6 on my home machine. Are you aware of any issues associated with this?
Symptoms: clicking "login" or "Reply" or "Post message" or similar just brings back the discussion forum front page, showing
satellites.co.uk/cgi-bin/webforum/forum.cgi in the adress bar.
However, it works fine at SatNerds.com and other web forums - thre must be something in your scripts that IE6 can not handle.
Any help / advice will be highly appreciated.
Many thanks,
Nickolai
Hi Nickolai, I run IE6 as well, but without any problems. You should check in Tools/Internet Options/Privacy/Edit Web Sites, Type in www.satellites.co.uk and press the Allow button. Make sure also that there are no other mentions in the excluded list.
If you've already tried this, then check also the Content ruling and make sure that there are no Funnies in there.
Rolf
Lower the security level or disable your Firewall when logging in
I have found problems with Symantec/Norton when set to high security
Nickolai
thanks for the hint - my gut feeling is you are spot on, it must be the Symantec firewall!
Rolf - many thanks to you too, but I tried these options before posting, and this still did not help! I thought I was going nuts!
Best wishes
Nick:-)
Nickolai
Channel Hopper and Rolf,
Thanks for your advice - it was the Symantec Firewall!
When disabled, everything works fine.
Many thanks
Nickolai
